D dfg555 Distinguished Jan 9, 2013 167 0 18,680 Apr 24, 2014 #1 solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved
Solution Dark Lord of Tech Apr 24, 2014 It will run the modules but will downclock them to 1333. It's just an example , it will work but will run it at 1333.
Ubrales Polypheme Dec 3, 2009 13,240 11 61,465 Apr 24, 2014 #2 I looked at the mobo link. The RAM link was broken. Here are the RAM specs on Gigabyte's website: Two modules - DDR3 DIMM sockets supporting up to 16 GB of system memory - Dual channel DDR3 2200(OC)/1333/1066/800 MHz memory modules Can you re-post the memory link? Or post the memory specs of the one you are considering. Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,793 1,852 159,590 Apr 24, 2014 #3 G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL G.SKILL 4GB F3-12800CL9D-8GBRL DS It's on the QVL list but states it will run it at 1333. Upvote 0 Downvote
D dfg555 Distinguished Jan 9, 2013 167 0 18,680 Apr 24, 2014 #4 G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL G.SKILL 4GB F3-12800CL9D-8GBRL DS It's on the QVL list but states it will run it at 1333. But how come on that QVL list it says 4GB? is this a typo or were they using 1 module? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,793 1,852 159,590 Apr 24, 2014 Solution #5 It will run the modules but will downclock them to 1333. It's just an example , it will work but will run it at 1333. Upvote 0 Downvote Solution
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,793 1,852 159,590 Apr 24, 2014 #6 Your Gskill link isn't working now , it worked earlier. Upvote 0 Downvote
D dfg555 Distinguished Jan 9, 2013 167 0 18,680 Apr 24, 2014 #7 Your Gskill link isn't working now , it worked earlier. Yes I had that same issue before, now it's working for me. Upvote 0 Downvote
