solved solved solved solved solved solved solved solved
dfg555
167
solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved solved
Depends on what resolution and settings he wants to achieve, if he simply wants to play at 720p on medium, a R7 250 can do that just fine.
or if you are asking for what is the best card that you can get, while still gaining the most performance for dollar.
He has a pretty beefy system 3 monitors, so yes I'm asking the best option for price to performance ratio.
