[Solved] Sony Vegas ignoring AMD Radeon HD 6670
Router1011
Hello, I have a Radeon HD 6670 that Sony Vegas 13 is just plainly ignoring. In the option area for GPU rendering, it just says "Off" and there is nothing else in the drop down. I am using the latest Crimson Drivers (15.11). I was wondering it maybe it's the Crimson Drivers causing the problem? Thanks!
Radeon Settings Version - 2015.1118.123.2413
Driver Packaging Version - 15.30.1025-151117a-296582E
Provider - Advanced Micro Devices, Inc.
2D Driver Version - 8.1.1.1533
Direct3D® Version - 9.14.10.1162
OpenGL® Version - 6.14.10.13416
OpenCL™ Version - 2.0.4.0
AMD Mantle Version - 9.1.10.99
AMD Mantle API Version - Not Available
AMD Audio Driver Version - 10.0.0.2
Has it ever worked? If yes, then roll back the drivers. Even if it's a first time you are trying it, I'd use older drivers. I have not been reading good things at all about the new AMD Crimson, and from experience with installing it, don't like it one bit.
Router1011
I'm reverting as we speak and I'll post the results here.
Router1011
Perfect! I grabbed 15.7.1 and it recognizes it! Thanks
