[SOLVED] System Freezing when Playing on Video Card Display
DhampirSG
9
Reverting Motherboard BIOS to Version 2.1 Fixed the Issue.
With ASrock Motherboards, Do not use the BIOS version 2.7 with the Sapphire Radeon R9 270X.
It was this BIOS version that started the issue.
Hi there,
I have started having an issue with my system where, whenever I try playing a Game using a Display plugged into my video card, the system freezes, and i have to power off/restart the system to do anything.
My system is:
Motherboard: ASRock FM2A78M-HD+
Processor: AMD A8-7600 @3.1Ghz/3.8Ghz (Turbo)
RAM: 16GB (2x8) Crucial DDR3 1600Mhz
HDD: 2x Seagate Barracuda 1TB
PSU: Enermax B500-SB 500W ATX PSU
Video Card: Sapphire R9 270X Toxic
With ASrock Motherboards, Do not use the BIOS version 2.7 with the Sapphire Radeon R9 270X. It was this BIOS version that started the issue.
Unfortunately no friends. and No money to get a new PSU
The Entire system is new. I was able to use it fine for about 2 weeks before this issue came up.
I just tried that. Didn't help. From memory, it happened just after i updated the Mobo's BIOS
didn't find out which one I had. but reverted to ver2.1. will update if it was successful, installing a game now.
Fingers crossed it works
With ASrock Motherboards, Do not use the BIOS version 2.7 with This card. It was this BIOS that started the issue.
