SOLVED: Thinkpad T420 does not recognize external drive
Corobori
30
For a few years I have been working with an HP Elitebook 8460p to which I connected an external drive, a Western Digital Element 2042. Working just fine. A few months ago I purchased a Thinkpad T420 and I thought that connecting the external drive would be a piece of cake but unfortunately no. So far I have been been enable to do so and I can't figure out why. When booting the drive doesn't show up in the drive's list.
I have been trying just about each port on my Thinkpad and none worked, the actual cable and port seem to work as the light at the back of the drive are on.
I know for a fact that the drive works, I just fired off my HP Elitebook 8460p again to make sure it was indeed still alive and it is fine. I can see it on my HP's boot menu and in the HP's disk management details. But not on my Thinkpad T420.
I used an enclosure with another drive to make sure the USB ports on my Thinkpad T420 are ok and this works fine. I also changed the drive's letters.
If the ports on the Thinkpad is fine if the external drive is fine, why then my external drive is not recognized by my T420 thru the USB port ?
This is the external drive's information as they are shown on the HP
You say you've had the Thinkpad for a "few months" now. Was there any problem with the USBEHD during that time or did the problem you describe only arise recently?
So is the USBEHD listed in Device Manager? Any listing in Disk Management?
Hi there Corobori,
That is unpleasant. 🙁
So, the drive is working just fine on your old laptop, but it is not recognized by your new one right? Does the drive spin up?
Could you please provide screenshots of Disk Management and Device Manager while the drive is connected to your new laptop?
It may be a good start to go to your new laptop's manufacturers website and update all the drivers.(especially the USB ones)
Let me know how this goes,
D_Know_WD :)
This external drive never worked on my Thinkpad
The disk doesn't show up neither in the Device Manager nor in the Disk Management
It does spin up, I can hear it and feel it too. The light on the back switches on too.
All done
Here is the Device Manager
Here is the drive
And here are my BIOS settings (I tried disabling the securitychip but it didn't change anything
Microsoft (R) Windows Script Host Version 5.8
Copyright (C) Microsoft Corporation. All rights reserved.
WakeOnLAN
current setting = ACOnly
possible settings = Disable,ACOnly,ACandBattery,Enable
EthernetLANOptionROM
current setting = Enable
possible settings = Disable,Enable
USBBIOSSupport
AlwaysOnUSB
TrackPoint
current setting = Automatic
possible settings = Disable,Automatic
TouchPad
FnCtrlKeySwap
current setting = Disable
FnKeyLock
ThinkPadNumLock
current setting = Independent
possible settings = Independent,Synchronized
PowerOnNumLock
possible settings = Auto,On,Off
BootDisplayDevice
current setting = LCD
possible settings = LCD,VGA,Digital,Digital1onDock,Digital2onDock
GraphicsDevice
current setting = IntegratedGfx
possible settings = IntegratedGfx,DiscreteGfx,SwitchableGfx
OsDetectionForSwitchableGraphics
SpeedStep
AdaptiveThermalManagementAC
current setting = MaximizePerformance
possible settings = MaximizePerformance,Balanced
AdaptiveThermalManagementBattery
current setting = Balanced
CDROMSpeed
current setting = Normal
possible settings = High,Normal,Silent
CPUPowerManagement
PCIExpressPowerManagement
OnByAcAttach
PowerControlBeep
LowBatteryAlarm
PasswordBeep
KeyboardBeep
SATAControllerMode
current setting = AHCI
possible settings = Compatibility,AHCI
CoreMultiProcessing
HyperThreadingTechnology
AMTControl
HardwarePasswordManager
LockBIOSSetting
MinimumPasswordLength
possible settings = Disable,4,5,6,7,8,9,10,11,12
BIOSPasswordAtUnattendedBoot
BIOSPasswordAtReboot
FingerprintPredesktopAuthentication
FingerprintReaderPriority
current setting = External
possible settings = External,InternalOnly
FingerprintSecurityMode
possible settings = Normal,High
FingerprintPasswordAuthentication
SecurityChip
current setting = Active
possible settings = Active,Inactive,Disable
TXTFeature
BIOSUpdateByEndUsers
FlashOverLAN
DataExecutionPrevention
VirtualizationTechnology
VTdFeature
EthernetLANAccess
WirelessLANAccess
WiMAXAccess
WirelessWANAccess
BluetoothAccess
ModemAccess
USBPortAccess
IEEE1394Access
ExpressCardAccess
UltrabayAccess
eSATAPortAccess
MemoryCardSlotAccess
SmartCardSlotAccess
IntegratedCameraAccess
MicrophoneAccess
FingerprintReaderAccess
ATpModuleActivation
possible settings = Disable,Enable,Disable
ComputraceModuleActivation
BootMode
current setting = Quick
possible settings = Quick,Diagnostics
StartupOptionKeys
BootDeviceListF12Option
BootOrder
current setting = HDD0:ATAPICD0:USBHDD:USBFDD:HDD2:HDD1😛CILAN:ATAPICD1:ATAPICD2:HDD3:HDD4
possible settings = HDD0,HDD1,HDD2,HDD3,HDD4,PCILAN,ATAPICD0,ATAPICD1,ATAPICD2,USBFDD,USBCD,USBHDD,OtherHDD,OtherCD,NODEV
NetworkBoot
current setting = PCILAN
BootOrderLock
ReserveMemoryForUEFIBootManager
Guys, I have solved this issue. On my trip to town I visited a place where they are fixing up notebooks. The guy in charge told me to purchase a dual USB cable, it wasn't easy to find one but I just got it and the external drive is now coming up nice and easy 🙂
