Hello guys!
I´m gathering a list of components to set up a pc. These are the parts:
Zotac GeForce GTX 1060 AMP! Edition 6GB GDDR5
Procesador AMD Ryzen 5 2600 3.9 Ghz
Asrock AB350M Pro4
G.Skill Ripjaws V Red DDR4 2666 PC4-21300 8GB 2x4GB CL15
Seagate BarraCuda 3.5" 1TB SATA3
Crucial MX500 SSD 500GB SATA
Apart from the possible issues that the motherboard-ram-cpu could cause, I´m concerned about installing fans, cases and PSU. Should I get a case with built in PSU and fans? Is it enought with just 1 fan (pcpartpicker says that the build consumes 180W).
Thank you so much!
Asrock AB350M Pro4
Thank you so much!
