G
Guest
Guest
This is going to be a long one guys, sorry about that. Up Votes and Best Answers will definitely be a thing in this thread.
Figured it was high time I went in for this overclocking mumbo jumbo. Held off before due to cooling requirements (Both CPU and VRMs).
I'm fairly confident I can achieve a modest overclock using the Corsair H80i and ASUS Sabertooth (990FX Rev.2) board. With that said this will pretty much be my first ever OC.
I mean, you could count the time I was 12 and set a school computer to 6GHz before swiftly running away while it began smoking from the case. That was jolly good stupidity and fun combined into one glorious mess of childhood toe-raggedness.
Pretty much all the specs can be found in my sig. As far as case cooling goes, I have 6 Corsair SP120 Quiet fans running at full-speed all of the time, two of which on the rad itself, and, 2 AF140 Quiets, also running full-tilt in the top. It's summer in England at the moment so things are a bit warm, which may need consideration, but it's basically sub-zero for the rest of the year.
Also, using a small amount of AS5, made sure to get a perfect mount with it recently which is rather tricky on the two-clips mounting bracket. All previous paste was thoroughly removed using Isopropyl alcohol until it came back clean on both the block and CPU.
The BIOS has the latest version for this board as of around a month ago.
While I'm fairly experienced with IT in general, overclocking is new to me. I get the basic concept, understand the jargon, but, as far as actually doing it, I'm rather hazy.
My aim is to achieve a decent OC without spitting out too much heat and at the lowest stable voltage possible (Obviously). In short. 4.4GHz should be achievable, 4.6 desirable and 4.8 as a possibly-in-reach-but-difficult-to-do-so.
While performance is the target I do still want to allow for some lee-way for longevity sakes. The future is as always uncertain, but I don't particularly want to be upgrading 3 years from now because the chip fried, or something.
Right then, on to the questions:
1. I've read a lot in to FSB overclocking. I'll be honest, I'd rather keep it simple and just stay in the CPU multiplier and voltage comfort zone. I'm happy to put a little bit of strain on the CPU itself, but not too cool with putting strain on everything else. My question then, is in regards to its setting:
I hear keeping it on 'Auto' causes it to overclock/overvolt itself depending on what I do on the CPU end, would I need to change it to 'Manual' to keep the original settings as they are?
2. I've been getting to grips with the AMD Overdrive software and like it very much. The current plan is to use it for the OC until I can find the right sweet spot, reset to default and then punch those settings in to the BIOS. It's quite the pain to get in to my BIOS since Windows boots 90% of the time before I can hit the button. I have to use the DirectKey button on the board itself, so this software is awfully handy. I'm pretty certain it doesn't change the BIOS settings to what you set, merely acting as a software wall, so it makes sense.
Would this be advised? Like I said it can save an awful lot of hassle if it is. I particularly like the Stability Test function.
3. Roughly, what kind of settings do you think I'll be aiming for here? How many MHz does a 1x multiplier equate to? and, Would you recommend upping this first until it becomes unstable and then pumping up the voltage slightly, rather than the up-voltage then OC method?
4. I've read in to turning off almost all power-saving features first, such as Cool n' Quiet, while this makes some sense, I would ideally like to use these when I reach the OC. Wouldn't it be wiser to just leave them on so that stability tests can factor in this portion also?
As for 'TurboCore', that will be disabled right from the get-go.
5. Finally, depending on the voltage set, aproximately how many extra watts do you think the CPU would consume at, say, 4.6GHz in the early 1.4v mark? I know that the 9590 is basically an overclocked 8350, on this PSU I can handle such a TDP, but for bills sake I'd prefer not to. Although, I do believe they used a mahooosive voltage of around 1.5v for that.
Well, that's about it. I'm pretty certain I can figure it out from there once I know the answer to these little details. As an extra, how much added performance do you reckon a .6GHz OC will achieve?
Thank you very much for all of your help in advance.
Apologies for the really long post, I would add a potato but I'm unsure about this forums' hot-linking rules.
