Some small problems
Michaelvdz
27
Hello everyone,
I recently bought this setup:
My parts:
ASUS H81M-E
eVGA GeForce GTX 770 ACX
Samsung SH-224DB
Corsair Graphite Series 230T Window
DeepCool GammaXX 300 (CPU cooler)
Corsair VS650 (650Watt)
Corsair Vengeance (2x4Gb)
Western Digital Red WD10EFRX (1T)
Intel Core i5 4670 / 3.4 GHz
Now there are a couple of small problems that came up.
The case contains 3 fans and there is only 1CASE FAN Pin on the mb.
Second problem is that the front panels has 2 USB 3.0 ports that I have to connect to the mb with a USB 20-pin female but there is no male version on the motherboard.
I hope to recieve some help or thought so I could finish my unit.
cball1311
1,622
Well, for the USB 3.0 front panel problem, you can't utilize them (with the cable above) because your motherboard does not have a USB3.0 header. You could get two of these these cables to run from the back of the case (motherboard ports) to the front panel connectors (through the case, of course).
http://www.newegg.com/Product/Product.aspx?Item=N82E16812422959
For the fan problem, if the fans have the larger molex connectors, you can plug them into any molex connector from the PSU. If they have small fan connectors, you are gonna need one of these.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812311003
Michaelvdz
27
Would this do the trick for the usb problem. There are 2 usb ports on the front panel. But would they both be usable if I connect this USB to the mb. Both ports form one cable which fits in this cable.
