Someone help me plan airflow in my case, air cooled crossfire r9 290s in a CoolerMaster 690 II Advanced. PICS
gandalfs
287
Hey can someone help me with airflow inside my pc, here is a link to the case.
http://www.coolermaster.com/service/support/model/RC-69...
I will use the elft and right side fans, i may only have space for one fan on the bottom due to the large PSU (i have rotated the psu). But i will modify if necessary
Here is a pic of my case.
http://imgur.com/wamKMao
Also i was thinking about getting some cheap Arctic Cooling F12 fans, they seem pretty good.
Any advise is welcome, will rep.
Where should i put those intakes?
I believe you can put one at the bottom coming in and use your front fan, I would probably see if you can move your front fan up by the hard drives and put in a static pressure fan there and replace your other fans with air flow style fans. I would look at the Corsair AP/SP series and also take a look at Noctuas fans, having 2 GPUs I would definitely go higher quality fans. You can also get Silverstones fans filters if you would like your case to be more dust proof.
Hi, could you explain the fans i dont understand.
Static Pressure fans work better with obstructions such as hard drives or a radiator and the flow covers more area and can move more air with obstructions. Air Flow fans send the air in straight line and usually move more air than a static pressure fan with no obstructions, but if there are obstructions the fan actually moves less air than a static pressure fan. Sorry this isn't the best explanation you can find more information on fan manufacturer websites or googling the various fan types.
Hi i iwll rep, but i'm running out of 3 pin space on my mobo, what should i do?
There are adapters for that, its a 3 pin fan splitter... Hope this helps, sorry for the late response.
