X xPC NOOBx Prominent Apr 17, 2017 6 0 510 Apr 17, 2017 #1 my pc says ddr3l 1.35 only. Can I change the voltage to allow me to put in 1.5v RAM?
Solution Zerk2012 Apr 17, 2017 You need to use 1.35 memory like it says. If you use 1.5 volt memory you will probably never get it to boot .
Zerk2012 Titan Ambassador Oct 6, 2014 22,338 2,408 104,240 Apr 17, 2017 Solution #2 You need to use 1.35 memory like it says. If you use 1.5 volt memory you will probably never get it to boot . Upvote 0 Downvote Solution
RCFProd Expert Ambassador Dec 8, 2013 12,605 29 56,990 Apr 17, 2017 #3 You might boot with 1.5V, but it might be dangerous for your motherboard depending on which one you have. Upvote 0 Downvote
