hello everyone!
im desperate for help, ive searched high and low and i checked and double checked to make sure all the settings are correct to have an SSD drive run at optimal speeds. i built my computer in January and ordered my first SSD drive last month so i still have time to RMA the drive if necessary.
asus sabertooth p67 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131702
intel i7 2600k @ STOCK
mushkin enhanced chronos 120GB SSD - http://www.newegg.com/Product/Product.aspx?Item=N82E16820226236
ive done a benchmark with CrystalDiskMark, ATTO and HD Tune however i am at work right now so ill post the results when i get home BUT
with the CrystalDiskMark program is says my SSD Sequential Read speed is 202mb/s and my Sequential Write is 125mb/s
i also have a secondary mechanical drive(Seagate Barracuda 1TB @ 7200RPM) so i tested it to compare and the mechanical Sequential Read
speed was 103mb/s and the Sequential Write was also around 100mb/s
so im kinda sad that im not getting the same results as other people, like 300+ mb/s read times, im running in AHCI mode and im plugged into
the intel sata6g_1 port on the mobo(not marvel) and im using a sata 6gb/s cable to connect the SSD to the mobo. i also updated the firmware
to the most recent version and got the same results.
i have noticed that windows and games load quicker but according to the test its not performing like it should 🙁
someon please help!
someon please help!
