EIDT
Apparently the 17GB file that wont show up in regular file explorer is a config file within system32 folder. Here's a screenshot of it's contents. Does it look ok to you? My Windows folder has 40GB thats seem to big to me
Hello everyone,
I have just discovered that something on my hard drive that has system on it is taking up around 20GB of space. I have unhide all the hidden files (even the system files), but I can't seem to find whatever it is that's taking up all the space. When I select all the files and folders on C:/ I get 47.6GB size on disk, but when I go to properties for C:/ in the Computer it says 67.3 Used space.
I have hiberantion turned off. Below are screenshots of the properties for the disk.
Computer->Local Disk C->Properties
Used Space: 67.3
Computer->Open Local Disk C->Select All->Properties
Size on disk: 47.6
The harddrive C:/ is on Intel SSD 330 - 120GB. And if it can help you here is a link to the HW in my PC http://www.czc.cz/69ak96712gh4p8sj075r96pqod/seznam It's in Czech language, but the titles underneath each picture are global.
I would like to know if you have any tips or advice on what it could be thats taking up all the space, or how to find it.
Thank you all for reading,
I am looking forward to your replies,
James.
Hello everyone,
Used Space: 67.3
Size on disk: 47.6
James.
