Question Something strange with desktop microphone audio
Jul 6, 2020
14
Hello, so i came across something really weird with my pc, the thing is, that when i try to record anything with my desktop microphone the thing picks up a lot of static noise, and when i put a hand on top of the pc case, the static sudently goes away, and if i remove my had from it, the static starts again, is there any way i could fix this?
SteveRX4
Notable
BANNED
Sep 29, 2020
1,477
135
890
20
OK then it's your PC. If you can fix it py leaving a weight where you had your hand then that should work.
If you don't want to do that then I need to know your PC specs to continue.
Jul 6, 2020
14
ryzen 3 3200g
2x4gb ram hyperx fury
asrock a320m-hdv
And a generic PSU
the pc is totally new, at first i did not have that problem, it started like 2 days ago
