Hello,
First off I am confused whether to post this in Graphics or Displays (or Components), but I thought this is most suitable. Anyway.
Sometimes when I turn on my PC, or reboot it, the monitor doesn't start as if PC is turned off.
When I leave the PC to complete booting, I connect through Remote Desktop and it works fine while the monitor is off. And I could control it through Remote Desktop.
To solve this issue I had to power cycle. Turn off the PC, switch off the power supply then try again until the monitor displays something.
What could be the cause of this problem and how to solve it?
My PC specs:
Thank you guys.
My PC specs:
Processor: Intel i3-2100 @ 3.10GHz
Memory: 8 GB (2x4GB)
Motherboard/Chipset: PH67A-D3-B3 (No integrated display)
GPU: Sapphire - AMD HD6850
Display: Samsung SyncMaster B2030
Display is connected through DVI-D
Temperatures are fine.
Thank you guys.
