Sony 2 Pin DC Power Plug Required
  • Thread starter Thread starter Guest
  • Start date Start date
  • Tags Tags
    ATI
G
Guest
Guest
Archived from groups: rec.video.desktop (More info?)
> Can anyone shed any light ? I have recently bought a Sony DCR TRV 265E. As
> with many other Sony Camcorders they use this funny little two prong DC
plug
> that connects directly to the camcorder to facilitate mains power or
> charging the battery.
> Always wanting more, I wish to power my camcorder with an alternative DC
> source, but cant find one of these plugs anywhere. Buying a seperate ac
> adaptor just to hack the plug off seems a bit excessive.
> My intention is to power the camera from several sources:
> Car (via cig lighter)
> Sealed Lead Acid
> 5 Std D type batteries
> 6 Ni-Cad's
> I have built an 8V dc regulator into an old walkman cigarette lighter
power
> plug which will give me 8V from the car or from the 12v sealed lead acid.
5
> Std D's will give me 7.5 volts and 6 Ni-CAD's 7.2 volts.
> The limiting factor however is the power plug. So has anyone been this
route
> before ? I have searched the WWW but cant find one. My last resort is to
cut
> the plug off my current cable and insert an inline connector so that I can
> use it for each of the apps above. However I would prefer not to
invalidate
> the warranty and find a spare.
> Please Help !
> TIA
You can probably purchase a car cigarette lighter adapter for the
camcorder, which will have the necessary plug for the camcorder, then
wire each of your alternative power packs for a cigarette lighter
plug.
"Colin Forsyth" <colinforsythnot@tiscali.co.uk> wrote in message news:<UUozc.475$lC3.108@newsfe3-gui>...
> plug
> > Sealed Lead Acid
> > 6 Ni-Cad's
> power
> 5
> route
> cut
> invalidate
> > Please Help !
> > TIA
I like your optism. Unfortunately, I havent been able to locate such an
item.
Col
"mikep76" <sandyprice@msn.com> wrote in message
news:be7373cf.0406142019.59f6457f@posting.google.com...
> plug.
265E. As
DC
> > plug
I'm in the US, where "DC Power Inverters" are easily obtained. I
don't know if that is true in the UK.
These devices plug into the cigarette lighter plug in the car, and
convert the 12V-DC into mains voltage which is provided in a
standard mains plug. So you could just plug your regular charger
into the mains plug of the inverter.
You have to be careful about the available wattage - if you plug a
1000 Watt hair drier into an inverter that can provide 150 Watts,
you can expect problems 🙂
See this as one example of many:
http://shop4.outpost.com/product/3972528
In this catalog entry, you can see the auto plug on its pigtail, but
you can't quite see the US-style mains plug on the end of the box.
Prices and other specs vary all over the place.
Gino
news:GCxzc.23$S81.6@newsfe3-win.server.ntli.net:
> such an item.
> Col
>> then wire each of your alternative power packs for a cigarette
>> lighter plug.
>> > > TRV
> 265E. As
>> > > two prong
> DC
>> > plug
>> > > power or charging the battery.
Gene E. Bloch (Gino) phone 650.966.8481
Call me letters find me at domain blochg whose dot is com
news:UUozc.475$lC3.108@newsfe3-gui...
As
> plug
> > Sealed Lead Acid
> > 6 Ni-Cad's
> power
acid.
> 5
> route
> cut
can
> invalidate
> > Please Help !
> > TIA
Colin, the subject of the Sony plug has come up before. There appears to be
two different size power plugs. I have yet to figure out what all of the
Sony power supplies do. I initially wanted to be able to charge a spare
battery without having it attached to my camera. Some of the Sony items are
a bit pricey.
B&H Photo carries some Sony adapters
http://www.bhphotovideo.com/
The exact URL does not remain, so you will have the search
DC-VQ11 DC Power Supply / Charger for S Series Batteries
DCC-L50B CAR BATTERY ADAPTER
AC-SQ950D AC/DC Power Adapter / Super Quick Charger - for M Series
Lithium-Ion Batteries
Rich
Thanks Gino that certainly gives me an option while on the move. I'm still
very keen to get my hands on one of these DC plugs so that I may build
alternative battery backs. The entire DCR- TRV range use them among several
others as well so they must be obtainable !
Regards
Col
"Gene E. Bloch" <hamburger@NOT_SPAM.invalid> wrote in message
news:Xns95097E5DFE404Astrolabe@63.240.76.16...
> Gino
