Sony corporate leverage or Sandisk quality problem?
G
Guest
Guest
Archived from groups: alt.comp.periphs.dcameras (More info?)
After purchasing a Sandisk 1GB memory stick pro it would not work in my Sony
Cybershot DSC-P150. I phoned Sony who blamed Sandisk saying that they only
recommend Sony branded sticks! I phoned Sandisk who say it is the camera!
When I told Sandisk that Sony will only recommend their own branded sticks,
the rep was not very happy. Apparently Sandisk pay a licence to be told of
any changes to the memory stick standards.
Is this just a smokescreen from Sandisk or are Sony deliberately
manufacturing cameras that only read their own memory sticks?
There is a lesson in this for me. Never, ever buy Sony with customer service
like that.
"FatDave" <gillild@REMOVEtalk21.com> wrote in message
news:Woyhd.3723700$ic1.374654@news.easynews.com...
Sony
only
sticks,
of
Take the stick back where you bought it from, and exchange it for another.
Also, take the cam with you so you can test the stick onsite! It's that
easy!!!
Seymore...
www.SonyCams.com
Sony F717
Nikon N90s
Nikon FM2
Nikon SB22 Speed-Light Flash
Nikkor MF 50mm 1.4/f16 -- AF 24-50mm 3.3-4.5/f22
Nikkor AF 60mm 2.8/f32 -- AF 35-135mm 3.5-4.5/f22
Tokina SZ-X 80-200mm 4.5-5.6/f32 -- AT-X 100-300mm 4/f32
remove "REMOVE" to reply directly
Sony
only
sticks,
of
Unfortunately the stick was bought mail order. I could send it back.and
probably will. My point is that in this era of regulated standards, the
correct spec of memory card from any vendor should work. I am concerned
that Sony may be fixing it so that you have to buy there own branded sticks.
"Seymore" <g_seymore@REMOVEhotmail.com> wrote in message
news:qImdneJcsrdVCBrcRVn-1w@adelphia.com...
> easy!!!
> Seymore...
> www.SonyCams.com
> Sony F717
> Nikon N90s
> Nikon FM2
> Sony
> only
>> camera!
> sticks,
> of
Typical Sony trick.
news:UwThd.3781348$ic1.379815@news.easynews.com...
sticks.
another.
> > easy!!!
> > Seymore...
> > www.SonyCams.com
> > Sony F717
> > Nikon N90s
> > Nikon FM2
> > Sony
> > only
> >> camera!
> > sticks,
told
> > of
> sticks.
Not much different though then Olympus cames *only* allowing panorama mode
on Oly memory cards.
Something BTW which I hated about them.
Gareee© (Gareee "at" Charter "dot" net)
Homepage:
http://www.fortunecity.com/tattooine/ellison/86/mainframe.htm
Custom Figures, Wallpapers and more!
