Sony HX90V Help
Jwade_
I own a Sony HX90V
I have a a 64GB card that has 80MB/s that I use to store the footage I capture with the camera.
I use the camera for Video, I'm not using it for photography.
All the videos that I take on the camera come out grainy/fuzzy, even though I have the camera set to XAVC S HD, 24p 50M
How can I fix this? How can I get true HD/1080p footage on the Sony HX90V?
please help I have tried to find videos on the cameras settings and the manual the camera came with is very vague.
Are you using the Auto settings for everything? Are the videos shot in well lit locations? Grainy/fuzzy sounds like there is either not enough light the gain is set too high.
Links you may find useful:
http://helpguide.sony.net/dsc/1510/v1/en/cover/level3_16.html
http://helpguide.sony.net/dsc/1510/v1/en/contents/TP0000586732.html
You could try the "Aperture Priority" setting to adjust the aperture and see which setting looks best or use the "Manual Exposure" exposure setting and experiment with the shutter speed and aperture settings.
