Sony pcg21313l display problem
xtreme101
please help me to repair/solve my laptop problems..if you turn on you got white screen, the capslock is working but in in external monitor not working ..please give me idea to solve this problem..thanks in advance...
Vague problem description. After searching web, found out it is a netbook. Important piece of info!
So you are getting white screen when turning on the netbook. Do you get the same result if you plug in an external monitor?
At what point you get the white screen? right after turning it on? Or after logging to Windows?
If you see white screen on both monitors right after turning the laptop on, issue is either video card or motherboard. Either case you need to change the motherboard. Cheaper to buy a new netbook, if not under the warranty.
