Sony srs db500
raivisbajals15
15
Hi i have sony srs db500 speakers when i listen it and turn more than half in a little while speakers turns off and red light is flashing when i disconnect it from electricity about 5mins and red light dissapears then i can turn it on and listen it again a little bit more than half. How to disable that turn off?
Found this...
When the "/1 indicator flashes
Immediately unplug the power cord,
and check the following items.
• Are you using only the supplied
speakers?
• Are the + and – speaker cords
short-circuited?
• Is anything blocking the ventilation
holes on the rear of the subwoofer
unit?
After checking the above items
and fixing any problems, wait for
5 minutes before plug in the power
cord again and turn on the system. If
the "/1 indicator still flashes, or if the
cause of the problem cannot be found
even after checking all the above
items, consult your nearest Sony
dealer.
Found this...
speakers?
short-circuited?
unit?
dealer.
