Well Sir, the fan is there for what? remove the heat as the electronics heats up, no fan, can't remove heat, laptop self-preservation electronics shuts it down before it starts burning.
I suggest reset BIOS configuration to default, and if that doesn't work, u will need to have it repaired.
