Sony X505 and similar products.
G
Guest
Guest
Archived from groups: comp.sys.laptops (More info?)
Hello.
I've looked at the Sony x505, and it seems like a really sexy computer.
I like the compact size of it, but I'm concerned about the low
capacity of the harddrive. It has a 20gig harddrive. I look
at medical images on my laptop. So 20gigs seems rather anemic.
Will Sony come out with the same compact model with a larger harddrive
capacity? What other products are out there that compare to the
sony x505 in terms of compactness? Image quality is also an important
concern too.
Any info? thanks.
G
Guest
Guest
On 13 Jul 2004 13:41:40 -0700, DaLoveRhino@hotmail.com (Love Rhino)
The X505 uses a 1.8" diameter hard drive - the largest of these is
40GB. I think some versions of the X505 have this, but if not you
could upgrade.
For similar-style laptops, check out www.dynamism.com.
Emanuel
G
Guest
Guest
"E Brown" <epbrown01@att.net> wrote in message
news:l4faf0h8je385oc3s474a2lnpt04j22mk1@4ax.com...
> could upgrade.
The 1.8" laptop drives are no advantage.
They are all very slow 4200 rpm units.
I would stay away from any laptops
that use a 1.8" drive -- except
perhaps for a very lightweight
travel unit to only read e-mail
and browse the net.
dk
