so i plan to use this TV as a monitor, but im concerned about potential lag when scrolling....is 4k at 30 hz for PC really bad/choppy?
my laptops dont have hdmi 2.0 (i heard most don't)....although I do have the original surface book....maybe active minidisplay to HDMI adapter will do the trick?
if I don't use the surface, which laptop should I get to support 4k as 60 Hz ? the issue seems two fold ...1) many laptops don't have hdmi 2.0; 2) this tv lacks displayport (not sure how many laptops have this port either).
I'd rather not use my surface as it's my portable laptop and I'm seeking a budget laptop to be used for the TV
if so, is this the correct cable?
[https://www.amazon.ca/Plugable-Disp...rt-Supports-displays-3840x2160/dp/B00S0BWR2K)
