SOS problem with hard drive molex pins, help?
zomboy
4
I bought a fan which came with a 4 pin molex extender. Stupidly plugged the extension into my hard drive. Unplugged it later on and it pulled out the yellow pin connector from the hard drive.
As I understand it that's the pin which carries the 12V current. So basically it looks like I've just screwed up my hard drive and essentially marooned all of my data.
Is it safe to try to re-connect the pin or try and repair it? What are my options?
Hi. First, those Molex connections are pretty much standard across the board, meaning, if the periphial has a molex connection, you can pretty much use whichever one is handy. Why it pulled the pin out, when you unplugged it, I don't know. It shouldn't have. Could have been a weak connection to begin with. Anyway, with out that pin, you are right your Data is marooned on the Hdd. One reason why you should back stuff up elsewhere. Anyway, without the pin, you will not be able to use the hdd. You can try to refix it as that seems to be the only option you have. There are companies that specialize in retrieving Data from Hdds, but under this circumstance, I don't know if they can. They are also expensive.
