Last night I installed all 4 Iobit softwares.The uninstaller, advanced system care, driver booster/updater, system defrag and the malware protection. First night no problem, everything running smoothly.
The next day, things start to act weird. My volume sounds very low, even though I increased the volume to the maximum, and it sounds weirdly as well. Something like its coming from underwater. Tried that on several sound sources. Programs take longer to load up, and this little square that you can use to select multiple programs at the desktop turned from the transparent blue square with a light shade of blue outline to the windows 7 outline, the dotted lines. I'm using windows 8.1 currently.
Also to mention, I updated 17 drivers with the driver booster, 14 last night, 3 this morning. 3 of them involving sounds. nvidia sound player and whatnot. After that update things started to act weirdly. Any help would be much appreciated, thanks.
EDIT: also programs freeze a damn lot more after all those events mentioned above took place.
