Sound auto adjusts????
Bat9th
29
Hi,
I recently have been having a problem...
When watching a Netflix or playing a game (Batman AA in this case). The voule level will be fine. Then on its own it cuts down to 25% or so.
In multiple windows watching Netflix the show will cut down volume but the normal PC sounds will stay regular volume...
I don't understand this. I can manually turn it back up but I get tired of doing so.
Any ideas?
THANKS!
Another thing.. I will be listening to music and it will skip then just stop playing. I can resume playing , but don't understand the stop.
what are you using to play music? if it's an internet browser then you likely using something like an online java or flash player to playback the music
same for online videos.
It's a problem with browser/plug-in or flashplayer/java software that you got. Basically make sure you've updated all those.
As far as sound cutting down in a game like B:AA, no idea.
I would also do due diligence on virus/malware scanning and also uninstall any web browser tool bars ( those things are ffing evil, yes really)
