sound blaster audigy se driver issue
snipester89
16
Bought a new sound card recently, the sound blaster audigy sb0570 and with windows 7 none of the tools (EAX, graphic equalizer..ect) will install. I get blue screen 0x131 whenever it gets to the part where it installs the tools. I googled this error code and nothing came up. I downloaded the latest driver (only) from creative labs and it installed fine and im using the sound card now. Whenever I click on the icons for EAX and graphic equalizers I get an error saying audio device supported by this application is not detected. Whats going on and how do I fix this? Usually vista drivers will work with this card but cant install them without the blue screen. If there's anything stupidly wrong with this post its because I'm re-posting this thread at almost 2am. Here is my pc specs if it matters at all to the problem (?compatibility?)
Motherboard - ECS a780gm-a (with most recent bios update)
Video Card - HIS HD 4850 512mb Overclocked to 730/1110
Sound Card - Creative Labs Audigy SE SB0570
RAM - OCZ Reaper 4GB DDR2 1066 5-5-5-15 @2.0v
CPU - Phenom Quad Core 9600 Agena 2.55ghz @1.325v
OS - Windows 7 32bit
Hi, I bought an audigy se today, and I am having this same problem.
I have downloaded all the latest drivers. I am trying to flag this up again because I haven't found any solutions anywhere. I have windows 7 64 bit
Someone please help me and snipester89, I would be very grateful.
System specs.
ASRock ALiveNF5SLI-1394
AMD Athlon 64X2 6000+ 3.0Ghz
Sapphire Radeon HD4850 Vapor-X Edition
4GB OCZ DDRII 800Mhz RAM
320GB SATA II HDD
Windows 7 Ultimate 64-Bit build 7100
CIC 750w PSU
I had that problem too when I upgraded to Win 7 x64. As I tried everything I just took it out and started using onboard. But you could try searching Google for the "Daniel_K" drivers. He's made all the stuff work under Vista.
Seems like there is a driver - hardware mismatch. I mean youmight have downloaded the wrong driver or you have got a different card that you think you have got 😉 Or something went perhaps terribly wrong during the installation, such as you still had another card installed while installing this one. Mu suggestions are:
1. Disable onboard audio in BIOS
2. Uninstall all audio drivers you have
3. Reboot
4. If you are 100% confident your sound card is Audigy SE
install this driver:
http://preview.tinyurl.com/yzy7mrg
Hope it helps..
