Question Sound Blaster Audixy FX Control Panel Won't Install
ajburr
65
I started running into a problem where my Sound Blaster card didn't seem to be working anymore. I have no idea why. I have USB headphones that work, but the speakers did not.
So I tried uninstalling and reinstalling the drivers, but that didn't work either. Then I thought that it might be the slot that the card was plugged into. So I moved it to the other slot in my PC, and I actually got some sound through the speakers.
Unfortunately the Control Panel for adjusting the surround sound speakers won't install. I run the program and it just hangs in the middle of installation. The progress bar never moves. I let it sit for about 10 minutes, which is way more than it needs, as I have a fast computer.
Does anyone have any idea what is going on?
