Sound Blaster Live! SB0410, Problem with 5.1 system?
Connecting
4
Sorry for my bad english, i'll try to explain my problem! I have Windows 7 and this card, i installed drivers and my surround speaker works. but Woofer does not work? My SW/CEN jack is connected to Orange Connector on card, i have tried to connect FRONT speakers to orange connector and problem is same, one speaker does not work, seems with rear speakers! But i try to "Test" my speakers with sound test in control panel and ALL SPEAKERS WORKS! What is the prob?
Surround sound only works depends on how that audio is recorded. If your playing a movie that is made with 5.1 surround sound, then it will play at 5.1 surround sound. But if a movie is made with 4.1, then you will only get 4.1
There is a way to make all speakers work, regardless of what your playing is has 5.1 or not. I've done it before, unfortunately I forgot exactly how I did it. :\
Try fiddling around with Creative's audio panel and set Windows 7's speaker configuration to 5.1
I did it all! But when i play some game or movie (5.1 movie) problem is same! I really dont know what to do.
Thanks for answer!
I had a integrated Sound Card and all speakers are worked on every Song/Music/Movie.
