Sound Blaster Sound Card Software Question
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I had just exchanged my Creative Sound Blaster Omni 5.1 sound card with another Omni 5.1 Sound Card. Since both cards are identical, I assumed that I don't have to uninstall and reinstall the sound card's software. Would this assumption be correct or do I need to uninstall and reinstall the software? Thanks.
If it is the same identical card you will not have to change or reinstall any drivers, install the card in the same slot.
Ranco58
