Hello,
Ok so this issue has to be experienced by someone else...
Basically it must be a driver crash for the SBZ Cards and it causes a whole heap of problems for my PC. The problem is extremely random, and as you can see it's taking up nearly 50% of CPU usage. I can't play games without extreme FPS issues, etc, even ending the software and drivers and restarting them doesn't fix it, only a restart.
I've updated the drivers, even went back to older ones. This issue is really annoying. Creative Support seems to be oblivious of problems and I can't use their forums cause they are extremely negligent when accepting new forum users to allow them to post.
The card it's self doesn't seem defective, doesn't cause issues without the software installed. No audio distortions or malfunctions, just this...
My PC specs are:
Win 8 64 Bit
i7 2600k
Asrock Z68 Extreme 3 Gen 3
16GB Gskill Ripjaw
x2 GTX 570's
Sound Blaster Z
My PC specs are:
Win 8 64 Bit
i7 2600k
16GB Gskill Ripjaw
x2 GTX 570's
Sound Blaster Z
