Sound Card Advice
ecko69x
12
Hello,
I am looking to buy a sound card for my PC. Which would you guys recommend between these two:
http://www.futureshop.ca/en-CA/product/asus-asus-7-1-pci-e-audio-card-xonar-dsx-xonar-dsx/10216262.aspx?path=7d88985cb030072cdcff1e1aaf34e9dfen02
http://www.futureshop.ca/en-CA/product/asus-asus-7-1-pci-e-sound-card-xonar-dx-xonar-dx/10216265.aspx?path=763d3d8154cf50c046f51b8233f81924en02
My motherboard is a Gigabyte GA-890GPA-UD3H revision 2.0. Will these sound cards work on my MB? Would I notice a difference in sound qualify if I'm using sound through http://steelseries.com/products/audio/steelseries-siberia-v2 ?
I don't like the DSX that much; reviews actually preferred the slighter cheaper DGX over the DSX, and it probably doesn't justify the extra price (all of $10 or so).
The DX is the superior card though, as the jump in quality from the DGX/DSX to the DX is significant.
Regardless, you should hear a significant increase in audio quality using any of the above mentioned cards with any decent headset.
