sound card decoder
Either/or/both.
Analog outputs are split by codecs, similar hardware is used in digital speaker systems to output the analog channels to the actual amplifier.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
so i want some of these
<A HREF="http://www.klipsch.com/product/product.aspx?cid=712" target="_new">http://www.klipsch.com/product/product.aspx?cid=712</A>
and a audigy zs, would i need to buy an extra decoder? or should i just get teh platinum.... and on the creative site, it says i need an extra decoder to playback movies in surround sound, true?
<font color=red>gforce mx100/200 @ 230/440 =]</font color=red>
If you need an extra decoder to play back movies in surround, then the sound card you're buying is junk.
Heck, I know you need extra cables to connect a creative card for 5.1 for system sounds, I'd just pick up a Dolby Digital Live card like the Turtle Beach Montego DDL.
Anyway, you shouldn't need any extra hardware except for cables. But it took my friend something like 2 hours to get his Audigy2 ZX to work with his speakers.
really? oh geez, creative is such a monopoly... any other sound cards that are superior to the audigy zs but around the same price bracket?
There are 3 analog connections to those speakers. You will use the L/R, Rear L/R, Center/Sub plugs on the audigy 2zs.
<A HREF="http://www.folken.net/myrig.htm" target="_new">My precious...</A>
"INPUTS:
6 analog discrete channels (3 stereo miniplugs), Auxiliary stereo miniplug music input"
<A HREF="http://www.klipsch.com/product/product.aspx?cid=712&s=specs" target="_new">http://www.klipsch.com/product/product.aspx?cid=712&s=specs</A>
Each miniplug supports 2 channels. It is 6 analog channels, just through 3 plugs.
