Sound Card Help
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Recently got a new sound card and installed it and it worked fine
but yesterday the computer went back and started using the default sound
card and the new one cant be used
says something about Card cannot start Code 10 when i try to install
hardware menu
new sound card Manufacturer: VIA - IC Ensemble, Inc.
Model: Envy24 Family Audio Controller WDM
Driver: envy24hf.sys
Monday, March 22, 2004
Supported
Old One
Manufacturer: Avance
Model: Avance AC97 Audio
Driver: alcxwdm.sys
Tuesday, February 11, 2003
Supported
G
Guest
Guest
Disable the onboard sound in the BIOS.
Cari (MS-MVP Windows Client - Printing, Imaging & Hardware)
www.coribright.com
"Shallowness" <shallowness@adelphia.net> wrote in message
news:%23KsUj%23ldEHA.2688@TK2MSFTNGP10.phx.gbl...
> hardware menu
> Supported
> Old One
> Driver: alcxwdm.sys
> Supported
G
Guest
Guest
i disabled it in the hardware profile for it and it did not work
"Cari (MS MVP)" <Newsgroups1@coribright.com> wrote in message
news:uT68GXmdEHA.3044@TK2MSFTNGP10.phx.gbl...
> www.coribright.com
> > hardware menu
> > Supported
> > Old One
> > Driver: alcxwdm.sys
> > Supported
G
Guest
Guest
BIOS is the system menu available upon starting up the computer. You
need to press the DEL key, F1, or F2 (one of them will get you into it).
This is where you need to find the onboard sound and disable it. Refer
to your motherboard manual for more help.
Nathan McNulty
>>www.coribright.com
>>>hardware menu
>>> Supported
>>>Old One
>>> Driver: alcxwdm.sys
>>> Supported
G
Guest
Guest
ok disabled it from there and then went to add hardware for the new sound
card and it still gives me the same error message
"Nathan McNulty" <nospam@msn.com> wrote in message
news:O8VgQgsdEHA.3612@TK2MSFTNGP09.phx.gbl...
> Nathan McNulty
> >>www.coribright.com
sound
> >>>hardware menu
> >>> Supported
> >>>Old One
> >>> Driver: alcxwdm.sys
> >>> Supported
G
Guest
Guest
OK, now try uninstalling the sound card drivers/software from Add/Remove
Programs in the Control Panel for you new sound card. Then try removing
it from Device Manager. Now reboot and reinstall the drivers/software.
See if that helps :)
Nathan McNulty
>>Nathan McNulty
>>>>www.coribright.com
> sound
>>>>>hardware menu
>>>>> Supported
>>>>>Old One
>>>>> Driver: alcxwdm.sys
>>>>> Supported
G
Guest
Guest
i cleaned my video card fan out just now and when i put it back in i hit the
sound card and it works now
> hardware menu
> Supported
> Old One
> Driver: alcxwdm.sys
> Supported
Thread starter Similar threads Forum Replies Date
S Windows XP 2
Similar threads
