Hi
I have the gigabyte z77x-d3h motherboard with VIA hd audio codec VT2021.
http://www.gigabyte.com/products/product-page.aspx?pid=4144&dl=#ov
From what i have read onboard sound cards have come a long way.
Will the Sound Blaster Recon 3d
http://www.amazon.co.uk/Creative-SB-Recon3D-PCI-E-Soundcard/dp/tech-data/B005IHM0W6/ref=de_a_smtd
produce better sound quality than my on-board audio? I am confused because the sound to noise ration and sample rates are lower (102 SNR, 96khz sample rate) then on my on-board VT2021 (110 SNR, 192kHz sample rate).
I'm planing to pair the sound card with sennheizer pc 320 headset. Is it even worth buying a discrete sound card?
I'm open to suggestions for alternatives but the card has to have optical out and a front panel connector.
Have been looking also at the ASUS XONAR D1 and the ASUS XONAR DX/XD which on paper seem better than the one from creative. Is there any other difference that the PCI vs PCIe? Also can I install the PCI-e card in the PCIE slot (8x or 4x) meant for graphics card? The reason is that my graphics card is blocking the pci1x slot and the other is dangerously close to the graphics card.
Are these cards noticeably better in sound quality than my VT2021 on-board?
Thanks
Thanks
