hi every one ok currently im having a slight problem with my Sound Card...first though here are my system specs
Windows XP Pro SP2 32-bit
AMD Athalon X2 5000+BE oc'ed to 2.8GHz
ASUS M3A78-CM
4GB DDR2 6400
250GB HD
Sapphire 4850X2
Creative SB Audigy 2 ZS
2X DVD-R drive....diff makes an modles.
anyways i decided to reinstall my Audigy 2ZS because i wanted to get better sound then what is available from the onboard audio, so i did so with no issues, installed the drivers again with no issues just fine. so once my system restarted i tried going into the drivers to set up my sound but every time i try any of the drivers applications i get the same message. The Audio Device supported by this application is not detected. this application will exit. im kinda baffled by this because i know that the drivers will not install unless they detect that the sound card is in the system. so does anyone know what i should do? an yes i am getting sound through the card so i dont know whats up...just cant get access to the driver apps
ASUS M3A78-CM
4GB DDR2 6400
250GB HD
Sapphire 4850X2
