Sound card or headphones?
maxinternet23
I won't have a wall of text here, I'll just cut to what is necessary 🙂
So, I have about £100 to spend on some audio upgrades for my computer. What I want to know: is it worth buying £100 headphones, if I am only using my motherboard sound? My motherboard costed me about £35, It says it is 8.1 surround sound.
So, I can 1: Buy expensive headphones, and use them with the on-board motherboard sound
Or, 2: Buy some fairly cheap headphones and a sound.
Any suggestions or advice is greatly appreciated!
i have an integrated soundcard pushing sound through my $1200 sound system and it sounds perfectly fine. however, i did buy a $300 motherboard with a reputable integrated sound card.
if you budget right, you could buy both.
as far as sound cards go, $20 soundblaster live cards work fine. there really isnt a need for $50+ cards unless you need the options.
as far as headphones go, they might be a little hard to budget but they are perfect: audiotechnica ath-m50
ive recently purchased a soundcard, which definitely boosted my audio quality on my pc.
ASUS XONAR DX
http://www.eio.com/p-30609-asus-xonar-dx-71-channels-pci-express-x1-interface-sound-card.aspx
but there are cheaper sound cards out there that you can fit into your budget.
i also occasionally run live sound, and i was in need for new headphones so i decided to invest in one, which were: SONY MDR-7506
http://www.amazon.com/Sony-MDR7506-Professional-Diaphragm-Headphone/dp/B000AJIF4E/ref=sr_1_1?ie=UTF8&qid=1320359174&sr=8-1
i honestly love them. fit comfortably. i sometimes forget that im even wearing them.
umm.. these INDIVIDUALLY fit your budget, but... both of them really were good purchases for me.
personally though, i think i would go with #1 and go with headphones first and try considering buying a soundcard in the near future. youll use your headphones more then the soundcard.
