Y YouJustGotCrafted Honorable Dec 4, 2012 35 0 10,530 Dec 12, 2012 #1 this sound card: Creative Sound Blaster Recon3D THX PCIE Fatal1ty Pro Sound Card SB1356 i need to know if this sound card will work/fit in a cooler master haf 922?
Solution BreadWhistle Dec 13, 2012 Anything that has PCI spaces supports PCI hardware. If your case didn't, you would be unable to even support a graphics card. So yes, it does.
BreadWhistle Honorable Sep 21, 2012 628 0 11,010 Dec 13, 2012 Solution #2 Anything that has PCI spaces supports PCI hardware. If your case didn't, you would be unable to even support a graphics card. So yes, it does. Upvote 0 Downvote Solution
Y YouJustGotCrafted Honorable Dec 4, 2012 35 0 10,530 Dec 13, 2012 #3 ok thanks and will it work with an intel z77 extreme6? Upvote 0 Downvote
Y YouJustGotCrafted Honorable Dec 4, 2012 35 0 10,530 Dec 14, 2012 #5 Best answer selected by YouJustGotCrafted. Upvote 0 Downvote
