Sound card to replace X-fi XtremeMusic PCI (8 years old)
rul3s
Hello there!
I have a Creative X-Fi XtremeMusic ago and a handful of years (8 in particular) and increasingly asked to be replaced, sometimes suddenly stops working, drivers for new windows is not brilliant, it is on PCI, etc. ..
The issue is that some time ago took a Asus Xonar DSX and has not convinced me anything, proved both official drivers as alternative, and I still think it sounds "loose" and less quality compared to the X-Fi, although it is obviously better than the integrated on my motherboard Gigabyte Z97X Gaming 5 (Realtek ALC 1150).
The issue is that I would like to buy a good sound card that works for PCI-e and last me another good season.
I use it mainly for listening to music with good quality (minimum 320kbps MP3, AAC, FLAC ...) and play CSGO, but I do not need features "gaming". I do nothing of musical creation.
I was thinking about taking the Creative Sound Blaster Z, but since I'm a little let down by the subject, because I ask to see if someone guides me some more about whether this suficiento or better I'll have to go to something better.
Greetings and thank you!
A suggestion for a sound card is dependent on a budget as well as being dependent on the sort of audio equipment you plan on hooking up to the sound card, which should also dictate the features it has to offer. It'd also help if you could pass on your full system's specs. inclusive of OS.
You could look into HT|Omega's Fenix...?
