Question Sound cracks/pops then volume changes
Oct 9, 2019
6
I recently upgraded to windows 10 and about a week ago I started having issues with my sound that I never had before. The sound will pop and crack and the volume fluctuates then either get quiet or really loud like someone kicked up the amp. I have uninstalled the diver and reinstalled it, tried different ones, tried a ton of different format settings, turning off enhancements you name it. I'm out of ideas please help. I'm starting to think it may be the sound card itself or the mobo but I have no idea how to check if its those things.
kaehligj
335
27
695
5
Nothing to do with windows 10.
Its a hardware issue, typically with the audio jack or the headset lead.
If its a bluetooth or replica (2.4Ghz Rappo) its commonly a battery issue inside the headset.
Oct 9, 2019
6
It's just my speakers. My headset is USB so it doesn't use the sound card from my understanding. My speakers are 5.2 surround speakers and I have tested all the jacks. They seem fine. Sorry I should have put that in the original post.
kaehligj
335
27
695
5
Try google the motherboard for drivers.
Then search for any proprietary sound drivers for that mb, download and install into Win10 and reboot.
Windows10 will always automatically install the latest certified hardware drivers, it may not fit your onboard audio machine.
Oct 9, 2019
6
Did that. A few times actually. With no luck :(
Oct 9, 2019
6
Popping and crackling in my experience has been a failing soundcard/amp.
Is there any way to tell for sure that this is the issue? I don't have another set of speakers to swap out and I really don't want to buy a set just to learn it was the card and not the speakers.
kaehligj
335
27
695
5
Hardware problem then ...
You recently UPgraded to Win10, leading me to think its an elderly PC?
Then you will have failing electrolytic capacitors in the speaker amp units.
I have a lovely 2.1 set lying around, but it is humming a lot from the mains, telling me the rectifier circuit is badly in need for help.
EDIT: does your set have any external volume control - this will certainly always become a problem over time.
The potentiometer will wear/corrode out and cause exactly the symptoms you describe.
6
If I use something to monitor my sound, if it's my speakers I would not see any change in the peaks when it glitches right? Because the software reads right from the card so if it's not peaking then glitches and still not peaking on the monitor then that should mean the card is fine right? Or would a failing amp on the card show no difference?
kaehligj
335
27
695
5
Ooops :unsure:
I have a bad habit editing my replies, I will try avoid that in the future.
You may excuse me I'm a 66yr old Git :censored:
Please re-read above post of mine.
Oct 9, 2019
6
Ooops :unsure:
If by external volume control you mean a long cord with a small box attached that allows me to control the volume then yes. Is there a way I can test if that is the issue? Because when I adjust the volume when it spikes I don't get any poping or anything and it changes the volume just fine.
