Sound device
al34
hello, my question is that i have a windows vista and it work ok until one day i go to use my sound and it said there was no audio output device installed ,it work fine before, what's up with that? does anyone no what i can do?
Well, you can try reinstalling the drivers for your sound card. If you're also feeling a bit adventurous, you can try opening up your computer, pulling out your card and reseating it on the slot. Not recommended if you're not comfortable.
What is your sound card anyway? Could be a conflict between it and Vista.
