[SOLVED] Sound Driver
tosbourne88
21
Hello all. My computer decided to randomly stop producing sound. Got the x by the speaker symbol in the bottom tray. When i go into device manager it says the Intel High Definition DSP has no compatible drivers. Download the correct drivers through the website, tried windows update, tried Lenovo update, bios update, 2 different "automatic" driver software, but still can't seem to fix the issue. on most of the software is shows that all drivers are installed and there are no issues. Not really sure where to go from here. Currently have tech support working on this issue as well, but they don't seem to be having any luck either. It happened without any updates. I was using the computer, then all of a sudden there was no sound and I had that driver error. Any ideas?
