Question Sound failing (realtek high definition audio device)
ashtekaros
18
i have 3 headphones. all of them are with a symilar problem. when i use them sometimes thay will work normally, but then the sound will fail , and will be symilar to someone "drowning" in water at times, making alow sound that i cant hear properly. this sometimes stops when i loosen the sound connector (something difficult to do, because it lead to the sound connector unplugging from the cpu). its a realtek hight definition audio device, on windows 7.
when i click on the volumes of the sound, they make the normal windows sound. the same happens when i test the sound on the sound configuration. what is causing this problem ?
