SOUND FIX F0R NO AUDIO DEVICE IN SOUND CONTROL
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
The solution is described at
http://www.annoyances.org/exec/forum/winxp/t1066427444 and I repeat the brief
version below (you need to reinstall the driver swenum.sys but first you must
create a .inf file for it):
"copy machine.inf from %windir%\inf to a temp dir
remove line 20: ExcludeFromSelect=*
add new hardware have disk (select the temp dir with the modified
machine.inf) and install the plug and play software enumerator"
G
Guest
Guest
It is usually a good idea if you post this connected to the original
post requesting the help ;)
Nathan McNulty
G
Guest
Guest
I did
> Nathan McNulty
