Sound from speakers only works after reset
The_Captainn
5
Hi guys,
I have Logitech Z333 speakers for my desktop PC which I bought in 2015. For as long as I can remember, and possibly right from the start, I have not been able to get any sound to come out of them when I turn the PC on for the first time. For some reason, starting and then resetting fixes the problem but I know that without fail they will not work when I first turn the machine on.
This problem does not affect earphones or headsets. I can get sound to come from them without any problems.
I'm pretty tech savvy but this is a new one on me. Any suggestions?
Thanks in advance.
Try the speakers using another audio source: e.g., CD player, iPod, iPad, another computer....
Update the audio device drivers on your PC. Could be some old bug that fails to detect or establish the correct/default audio port at first boot.
Ralston18
The_Captainn
5
Thanks buddy. They worked perfectly with my laptop and in the end downloading the latest Realtek High Definition Audio drivers seemed to solve the issue.
Latest posts
