Question Sound issue with DP Monitor
Onigokko
34
Alright so I have been having this issue for awhile now. Basically my main sound is coming from my DP Monitor (that has speakers on it). Luckily it also has an audio jack that I can connect my speakers/headphones too.
The annoying problem I am running into is if I try and plug it directly into the PC the sound dosent work.
If I keep my speakers plugged into the monitor, the sound will work out of the speakers. If I then plug my headphone into my PC, the sound works.. kind of. It is super quiet and I can barely hear anything out of it.
Thing ive tried: Reinstalling Drivers (realtek). Disabling the DP Audio. Making Speakers Default. Loudness Equalization.
At this point not sure what to do.
Lutfij
Might want to list your specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
Have you made sure the default audio device is your sound card(and not your DP monitor)? Might also want to mention the make and model of your headphones/headset since a 4 pole headphone jack can be an issue. Latest BIOS revision for your motherboard?
