T theevilgenius 101 Reputable Jun 17, 2014 3 0 4,510 Jun 17, 2014 #1 Alright so I upgraded from windows 7 to windows 8 and my sound went out ive looked in device manager for problems/ updates I just really would like sound. Please help thank you in advance
Solution Eduello Jun 18, 2014 What about the motherboard? http://www.computerhope.com/issues/ch000504.htm Also, are you using a dedicated sound card or are you using the sound from the motherboard?
Eduello Judicious Mar 2, 2014 9,075 0 32,960 Jun 17, 2014 #2 What are the specs of your PC? Upvote 0 Downvote
T theevilgenius 101 Reputable Jun 17, 2014 3 0 4,510 Jun 17, 2014 #3 Eduello : What are the specs of your PC? CPU: Core 2 duo 38400 3 ghz GPU amd radeon hd 6450 1gb RAM: 4gb ddr2 SOUND CARD: it just pops up as high definition audio device Upvote 0 Downvote
Eduello Judicious Mar 2, 2014 9,075 0 32,960 Jun 18, 2014 Solution #4 What about the motherboard? http://www.computerhope.com/issues/ch000504.htm Also, are you using a dedicated sound card or are you using the sound from the motherboard? Upvote 0 Downvote Solution
T theevilgenius 101 Reputable Jun 17, 2014 3 0 4,510 Jun 18, 2014 #5 Eduello : What about the motherboard? http://www.computerhope.com/issues/ch000504.htm Also, are you using a dedicated sound card or are you using the sound from the motherboard? I fixed it on my self it was trying to use the audio input to make sound so I canged it to the speakers still thanks ill choose u ass solution Upvote 0 Downvote
Eduello Judicious Mar 2, 2014 9,075 0 32,960 Jun 18, 2014 #6 Well good to know you figured it out Upvote 0 Downvote
