Question Sound not working while mic does
martin5718
Commendable
Oct 5, 2016
So I have a pair of headphones with two 3.5mm jacks at the end of the cable, they're both connected to the motherboard's audio card in their right openings. Everything worked fine until I installed the newest version of Realtek (the audio driver I was using before when it worked). Then it all stopped working well at least the sound, my mic still works.
I've tried so many things already, one of them being that i switched the cable from the back to the front and now i have sound but obviously the mic doesn't work that way. So what I think might be a problem but I'm not sure, as I don't want to screw up the current sound I have at the moment, is that I have (Realtek(R) Audio) on 2 places in device manager. As you can see here.
The upper Realtek driver has version 10.0.18362.1 and the one at the bottom has version 6.0.8781.1. Could it be that the conflict with each other? So I need do disable one of them? But I'm not sure which and what the problem would be otherwise. Please help...
