So I recently posted that i'd had problems with crackling sound on laptop. I was told it was the motherboard but was expensive to fix. So my idea was to connect an external sound card bypassing the sound chip inside fixing the problem or at least improving the sound. This picture was provided as a suggestion
Thanks
Unfortunately I got one of these and it did absolutely nothing the sound is still crackling. How could this be? I was sure this was going to work because this external sound chip is nothing to do with the motherboard inside. What does this mean? what is it that can be causing crackling even on an external chip.A good option would be to first test it with something inexpensive before going all in. Something like this, and see if it makes any difference at all...
https://www.walmart.com/ip/Usb-Soun...MIn7W95o-LjgMVPF1HAR11aCdTEAQYAiABEgKj0_D_BwE
Thanks
