Hey Peeps,
I'm trying to setup a VM that will be acting as a separate environment, like having a separate computer. I've been able to set the majority of this up just fine; however, I am running to a problem with sound. I'm using VMware Workstation 12. Host is Windows 10 Pro. VM will be using Windows 8.1.
Right now all sound goes to the host that is using an Asus Xonar Essence STX sound card. Ideally I would like to see if I can split the sound to where the host only plays what is coming through for the host and the VM's sound comes through separately for a more isolated environment. Would I be able to utilize the mobo's I/O for the VM? Would I need to install a 2nd sound card? Or is it not possible do to what I'm inquiring about?
Hopefully, I was clear enough to understand. If not please say so and I'll try to clarify more efficiently.
