M mehulc Distinguished Aug 3, 2009 2 0 18,510 Aug 3, 2009 #1 There is sound problem in my computer. I tried speaker as wel as headfone but no result, i have installed drive and in device manager i checked there is no yellow color exist in sound section... Please help
aford10 Champion Oct 2, 2008 15,649 2 51,960 Aug 4, 2009 #2 control panel-->sound-->audio tab-->do you have a default audio device selected? Check the volume control and make sure it's not muted and turned up.
M mehullotwala Distinguished Aug 19, 2009 1 0 18,510 Aug 19, 2009 #3 Yes default audio device is selected. It is something like 3-media...
aford10 Champion Oct 2, 2008 15,649 2 51,960 Aug 19, 2009 #4 Are you plugging the speakers into the right port? It's usually a green one.
M mehulc Distinguished Aug 3, 2009 2 0 18,510 Aug 20, 2009 #5 Yes I have tried all the ports including green one
aford10 Champion Oct 2, 2008 15,649 2 51,960 Aug 20, 2009 #6 Do you use an add on sound card or onboard sound? Check the BIOS to see if audio is enabled. Probably under the integrated peripherals section.
